Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-16-2003, 01:23 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Can someone explain turbo lag to me?
i know the basics that means you dont get full power until the turine in the turbocharger is spinning as fast as it needs to be. but why do people complain about it so much? do you accelerate slower than stock until its spooled up or do you just accelerate normal until its spooled then you get a jolt?
Old 04-16-2003, 01:29 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 04-16-2003, 05:01 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
turbo lag is the time it takes for a turbine to spool up between throttle plate closings.
usually a handicap between shifts if you lift and shift.
Old 04-16-2003, 07:26 PM
90gs's Avatar
oh well if you just accelerate normal i dont see whats so bad about it except for 1st gear, because if your racing once your in 2nd you'll be high enough rpm that the turbo lag wont be an issue... i played some game that tried to simulate turbo lag and from what im hearing from you guys its totally fake because they made you accelerate like 1/3 as fast as stock until you hit 4000rpm if you were running more than 15 pounds of boost
Old 04-17-2003, 01:16 AM
drift's Avatar
games =/ real life
Old 04-18-2003, 08:12 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Lag will depend on how "big" the turbo is, the "length" and "diameter" of the piping, along with how big the IC is...
"Noth'in like Induction..."
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 05-02-2003, 01:17 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
turbo lag
turbo lag is just a term from the time you hit the gas to the floor till the time the turbo reacts and puts the power to the wheels.. bigger boost, and bigger turbines are a way to defeat/ lessen this turbo lag time, but it will be ever present in any turbocharged vehicle.. Superchargers however do not have this turbo lag as they are not driven by exhaust gasses, but by the engine cranks itself. but there are downsides to SC's as well...
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-02-2003, 08:44 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: turbo lag
actually, thats gonna increase the lag cuz it takes longer to get bigger turbines spining, cuz bigger almost always means heavier.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 05-02-2003, 10:02 PM
depends on the engine really.. like the "sanddog" car in last months "honda tuner" which reached a record for civics 204mph! woo, not bad for a 4 banger... but that sucker was totally stocked in the engine compartment... and the big ass turbo in it. bigger turbo more boost, and yes, I must have been on crack last night when I wrote that post. what I meant to say is bigger turbo more boost/power, the lag is kinda just there with any turbo system, only way to get rid of it completely is to run N/A or get a SC, but SC's are not all that great, and they don't give you that nice hiss from the wastegate. to reduce your turbo lag you have to learn how to drive with the turbo, and how to keep the rev up between shifts so you can minimize the turbo lag.
Old 05-03-2003, 04:48 PM
94tegRS's Avatar
how quick does a turbo actually slow down.
say I takre off in 1st, the turbo spools, and I shift at 7k, it only takes me like .5 seconds to be back on the gas, and even down around 4 it is spooled, so can it really slow down that much in half a second to where you have lag time when it spools back up, doent it stay spinning fats enough to provide boost instantly once you ar on the gas ater you shift
current
history:
Old 05-04-2003, 04:02 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
The "hiss" comes from the blowoff valve, and superchargers can also have this
There's no replacement for displacement...No, not even a turbo.
can someone explain this code to me? bluemoon541 '96-'00 Civic 4 01-11-2005 11:39 PM
Can someone explain compression to me in english Ricochet Engineering/ Technical 13 06-20-2003 03:34 PM
