Old 04-16-2003, 12:21 PM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
main relay??
hey my car wont start unless i use starting fluid and i was tracing down the problem and it seems like not enough fuel is getting in the fuel rail but i wanted some sort of test to do on it to make sure is there any way to tell for SURE???
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 04-16-2003, 12:36 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
does your car have DPFI or MPFI?
Old 04-16-2003, 12:45 PM
well its MPFI i just converted it its a ZC the car ran great then yesterday it just died when it was idling i went to rev it and BLAM it just sputtered and died then after that u gotta spray starting fluid in it... here is the stuff i replaced soo far... new cap new rotor new plugs new wires new fuel filter new radiator hoses new hose's all over new radiator new water pump new timming belt.... so here is what i did i took off the fuel hose's to the fuel filter and and looked at the fuel coming out when i had someone turn the key but not much fuel came out then someone suggested it might be the main relay he said that he has fixed 4 honda's in the past year that came into his shop that were NO STARTS that he had to feed fuel so i'm checking on that but what else could it be i didnt think it could be a stuck injector or clogg'd one cuz they seem to work good is there a way to test them?? cuz that seems to be the only other thing that could be wrong besides the FPR...
Old 04-16-2003, 12:58 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
will it start if u keep turning it over, or what happens? Before it stalled was it idling high or low?
Old 04-16-2003, 01:47 PM
it was idling normal just at 800rpm then went i went to take off it just died then after that i tried to start it it would idle then it would sputter then die then after a little bit of trying it would completly NOT start unless u sprayed some starting fluid
Old 04-16-2003, 01:52 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Have you got a spare distributor to swap out? Mine acted up like that, and I had changed all the stuff you did, so was pretty mystified. I'm betting you have an ignitor or distributor problem.
Good luck.
Flunky
PS-Hey! Before you muck around with possible fuel problems, make sure you have spark! Pull a plug wire off of the plug, stick a screwdriver in the plug wire so it contacts the little metal part that goes around the spark plug. Hold the screw driver so the metal part is just a hair away from the engine and not touching anything else, and have a buddy turn the key. Then you'll know if it's a spark problem or a fuel problem. You should see a nice, fat, blue spark.
PPS-Oh yeah-Make sure you don't have any gasoline anywhere when you check the spark!
Old 04-17-2003, 08:23 AM
see if i had a spark problem would the motor still run if i put starting fluid in the motor?? cuz here is the deal no matter what i do i cant get fuel to the fuel filter and i put a new fuel filter on and it still wont fill up i get NO fuel at the fuel rail but my main relay works my pump turns on and injectors fire i get spark everything seems to be working except my pump seems to be turning on just not pumping fuel
Old 04-17-2003, 09:11 AM
95civicman 95civicman is offline
my zc wouldn't start because the injectors were clogged. try some fuel cleaner.
zc powered 89 CRX SI with some more stuff.
Old 04-17-2003, 09:17 AM
AF Premium User
It's possible to have a weak spark. Then it'll run, but it won't run well and it won't start up like a happy camper. That's why you look for a fat, blue spark.
It does sound like a fuel problem. Your fuel pump puts things under high pressure, so if you had leak, then you'd see fuel squirting out somewhere.
Beats me!
Flunky
Old 04-17-2003, 09:19 AM
AF Premium User
I know this is dumb, but....do you actually have gas in the tank? That would explain why it mysteriously quit, but then fired up again (fumes) and now you have no fuel at the filter...
Flunky
Old 04-17-2003, 10:51 AM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
When was the last time you changed your fuel filter? You may need to change that.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 12-30-2003, 10:52 PM
Serpiko Serpiko is offline
Re: main relay??
Maybe vapor lock? Cracked fuel line? Check fuel pressure.
Old 12-31-2003, 02:47 PM
alexdog69's Avatar
alexdog69 alexdog69 is offline
Re: main relay??
If you are looking for things to replace:
Main Relay and Ignitor
Old 12-31-2003, 03:05 PM
alexdog69's Avatar
Re: main relay??
And yeah... Take a spark plug out and ground the threads on it to your valve cover acorn nut and have someone crank the motor over.. If it don't spark then you might want to add coil to that list too...
Old 12-31-2003, 03:30 PM
Magik Si's Avatar
Magik Si Magik Si is offline
Re: Re: main relay??
Ditto...that sounds VERY familiar...try the main relay...it controls a LOT of things...mine still worked when my car acted up...but when I switched it...it never acted up again.
Good luck...and let us know what it was when you solve the problem!
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Is the main relay the same thing as the MASTER relay? lvpj Accord/TSX/Accord Hybrid 9 09-16-2005 11:21 AM
fuel relay/main relay eyescott Prelude 22 09-10-2004 11:51 PM
FYI on Main Relays... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-06-2002 12:28 AM
