Old 04-16-2003, 10:50 AM
91civhatch 91civhatch is offline
Help
Hi guys im changing the timing belt and water pump on my 91 civic dx 1.5....Problem is i cant get the crank pulley off 2nd i was looking at it there is no mark because i do know the camshaft where it says up needs to be aligned with the arrow on the crank PLEASE help im stuck..
Old 04-16-2003, 10:54 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
well did u lock it up or something, because if its not locked up its not gonna come off but even then u usually cant get them off with a regular socket wrench maybe if you use an extension of some sort i used the bar from my jack to give more leverage but then again i also broke my socket wrench but not on the crank pulley
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 04-16-2003, 10:59 AM
im trying to get a hold or a breaker bar or pipe thing im worried about is the timing alignment
Old 04-16-2003, 11:08 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
I'm not even gonna get started on the crank pulley but do a search, there's been a bunch of posts about that damn thing..
as far as the mark on the camshaft...put the cam gear on and the mark is there..
SOLD!
help me help me help me please fuel pump help my90horsy Mustang Talk 16 12-05-2003 09:38 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Help Help Help Help Help lewdaka03 Jetta/Vento/Bora 1 06-02-2003 01:57 PM
Help Help Help Help Help Help Help Help Help Help del_blond '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-05-2002 03:05 PM
Help Help Help !!!B20b!!! Help Help Help HondaCivic405 Engineering/ Technical 0 04-05-2002 01:51 PM
