Old 03-21-2010, 09:50 PM
JCF JCF is offline
2001 Grand Prix ABS Traction control lights
The warning lights are illuminated for both ABS and Traction Control. I have a code for the left front wheel sensor. How do I know if it is the sensor or the wire harness that is bad. Can I check voltage in harness and resistance in sensor? If so what are the correct readings?
Thanks!
Old 03-21-2010, 10:11 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: 2001 Grand Prix ABS Traction control lights
Check resistance on sensor terminals. You should have 50 ohm. If it's too too low, replace it.
If it's too high, try to clean contact with ethanol. If no luck replace it.
Most of the time, it's the sensor.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 03-21-2010, 10:46 PM
JCF JCF is offline
Thanks for your reply. Earlier today I hooked up an ohm meter not really knowing what to look for; it appeared that I had total continuity, no resistance. If I understand your quote this means the sensor (wheel bearing assembly) requires replacement?
Old 03-21-2010, 10:48 PM
You don't need to replace the wheel bearing. Just extract the sensor from the assembly and replace it.
Old 03-21-2010, 11:04 PM
JCF JCF is offline
I thought the whole wheel bearing asssembly and sensor came together as one unit; do you still need to remove the whole wheel bearing hub assembly to replace the sensor>
Thanks again!
Old 03-21-2010, 11:33 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I disagree. You replace the complete hub assembly. The wheel sensor is not replaced separately on these hubs.
Wheel sensor resistance is around 1K ohms give or take and not 50 ohms.
Timeslip 08/12/06
AF Community Guidelines
Old 03-21-2010, 11:52 PM
JCF JCF is offline
Thanks
Old 03-22-2010, 09:04 AM
Oh sorry. I was comparing to other car's system. I don't know this model specifically.
Old 04-14-2010, 07:40 AM
cno22 cno22 is offline
Hi,
Yes, everthing is one unit inside the wheel bearing. You have to replace the front wheel bearing that is bad. Had 2 of these go on my 01 prix.
