Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-21-2010, 02:38 PM
rodgerturner rodgerturner is offline
Relieve Fuel Pressure
What's the best way to relieve fuel pressure so I can change the fuel filter and replace the fuel pump assembly? Need to do some troubleshooting but I know the fuel assembly is bad.
Horrible gas mileage...11 city/17 highway right now. I just sea-foamed the engine. It otherwise runs pretty good. Other suggestions?
Old 03-21-2010, 07:01 PM
kornjulio kornjulio is offline
Re: Relieve Fuel Pressure
I never bother...but that's just me. You could start it up, then remove the Fuel Pump Relay, I suppose....
As for the crappy mileage, guess I'd start with the basics. Check air filter, replace fuel filter, check fuel pressure, compression, etc....
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
Old 03-23-2010, 01:06 PM
dewaynep dewaynep is offline
You will have to either pull the electrical connector to the pump or relieve the pressure at the fuel rail between the ps pump and the alternator. If you remove the fp relay it will not stop the fuel pump as there is redundancy in the wiring. The easiest is to disconnect the wiring harness at the tank.
Old 03-23-2010, 02:58 PM
lesterl's Avatar
lesterl lesterl is offline
Pull the FP fuse, there is no redundancy there and it is easiest. I have yet to "relieve fuel system pressure", that is done by disconnecting the connection at the filter with a catch pan under the filter.... :-)
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
