Old 03-20-2010, 02:09 PM
jmbegin jmbegin is offline
Send a message via MSN to jmbegin
2001 Silverado mystery problem. Comes and goes
Hey Guys/Girls,
I'm having a start problem with my 2001 Silverado. Every few weeks this happens. I try 200 times if I want with no luck. I let it sit over night... starts first shot next day. Then it's fine for a few more weeks. Runs great otherwise. So confused.
Here is a video of the problem happening.
http://www.youtube.com/watch?v=61gfd9Vxb80
Don't make fun of my pants I was painting my kitchen ok!
JM
"You got the Haynes Manual?"
"Yup!"
"Ok great, now take the car apart and spread it across the floor in little pieces and we'll get started"
Old 03-20-2010, 03:33 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 Silverado mystery problem. Comes and goes
Originally Posted by jmbegin View Post
Hey Guys/Girls,
JM
Did I see your right foot on the gas pedal?
When no start you need to check for lose of fuel pressure or lose of spark.
What does the security light do when no start?
Like key on light up for bulb check and go out or stay on?
Will it start with a shot of carb cleaner into intake?
If so you have a fuel delivery problem.
If it has spark to plugs when no start .
Hook up a fuel pressure gauge and post back fuel pressure readings on engine cranking.
What is the engine size?
Any code or check engine lights on?
MT
Old 03-20-2010, 03:57 PM
j cAT j cAT is offline
Hey Guys/Girls,
JM
with the nature of your failure to start , then normal operation for a few weeks this is most likely an electrical issue...
when it fails check the fuel pressure , check for voltage at injectors, spark at plugs , disconnect maf connector see if it starts ...
check all fuses for tightness in the socket if too loose this will cause random failures...also remove clean and the reinstall all engine compartment grounding points , then the fuel pump grounding at the fame rail fuel tank area ...
I have seen the crank sensor fail with a very intermittent engine run start condition ...check connections to it as well ...mounted under starter ....
Old 03-20-2010, 04:02 PM
ha ha no foot on the pedal its FI no point.
no loss of fuel pressure or spark
security light comes on but i dont know for how long. I do not that it comes on randomly while im driving at hwy speed but when it does there is no effect to performance at all.
Have not tried carb cleaner... (Keep in mind, it does start it just turns off right away) [See video in original post]
If problem persists we will send you pressure report on engine cranking.
Engine size is 5.3L
There is in face a code P0336
Just not, after letting it sit for 1 hour, I tried to start it after doing a OBDII reading and it fired right up.
I think it's because I pissed on it. Maybe that smartened it up.
Anyway, not sure when it will happen next time but I'll keep you posted. Maybe that code will help you.
JM
"Yup!"
Old 03-20-2010, 05:03 PM
MT-2500's Avatar
AF - Advisor
Engine size is 5.3L
JM
Better work on that code P0336 crankshaft position sensor.
As J Cat tells us they have a lot of internment fails causing a sometimes no start.
Good Luck and let us know how it goes.
MT
Old 03-20-2010, 05:14 PM
Checked Haynes manual. Says 2000 and older have that sensor... could it be that my 2001 was built in 2000 and it has that sensor?
"Yup!"
Old 03-20-2010, 05:28 PM
MT-2500's Avatar
AF - Advisor
Better pitch that haynes manual in trash can.
They have been known to lie to you.
Why do you think you think you are getting a code P0336?
Is it a history or hard code?
For good repair info get a factory repair manual or
http://www.alldata.com/products/diy/index.html
As J Cat said look behind the starter for crankshaft sensor.
MT
Old 03-20-2010, 06:16 PM
ya the manual sucks.
its a hard code... brand new
"Yup!"
Old 03-22-2010, 08:22 AM
shoman44 shoman44 is offline
----P0336---- Inspect for poor connections at the CKP sensorTest for poor connections at the PCM for the CKP sensor circuits
Inspect the CKP sensor for signs of damage if that all looks good Replace the CKP sensor.. I have run into a bunch with oil screwing the sensors up oil in the plug itself, Even though there sealed after time there not sealed very well. good luck let us know.
Old 03-22-2010, 11:33 AM
MT-2500's Avatar
AF - Advisor
If it is showing a hard code after code clear and you have replaced the sensor you have a wiring/plugin or VCM problem if the new sensor is good.
Get a good repair flow chart for that code and go all of the way threw it.
Let us know how it goes.
MT
