Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-20-2010, 01:01 AM
mattd424 mattd424 is offline
omg plz help
ok got alot of different suggestions so here is what i did pulled intake and put ne gaskets in cleaned everything i coated all my gaskets with red high temp rtv plut it all together check engine light on it runs hot it has to be wide open to start
you can baby it down to 800 rpm and it runs better than ever it also pours coolant out back right side of intake manifold.did i do somthing wrong?if i take it all apart to i have to buy new gaskets and rtv?
any help very much appreciated
Old 03-21-2010, 01:12 AM
Re: omg plz help
am i not suppose to cover them with that red rtv?
Old 03-22-2010, 11:44 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: omg plz help
I put my stuff on dry to avoid having areas that the sealant cures quick on/lumpy.
Also, when you put gaskets on, you need to check that covered passages are covered and open passages are open. Compare against the old gasket.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 03-27-2010, 01:17 AM
Re: omg plz help
wow i made i huge dummy move had put em on upsidedown.truck runs great and appreciate all hellp......and now the saga continues randomly my oil pressure light comes on it used to do it at low stalling rpm but now stays on occasionaly and i did end up hearing it knock.im scared i gotta drop the oilpan the valley under the intake was covered with burt flaky oil and dirt
Old 03-27-2010, 07:12 AM
AF - Advisor
Re: omg plz help
It's kinda troublesome but you do need to see if the oil pump screen is blocked.
Old 03-27-2010, 11:40 PM
Re: omg plz help
dang do you have to remove exhaust on the dodge to do it?
Old 03-29-2010, 01:18 PM
AF - Advisor
Re: omg plz help
Probably so.
Old 03-29-2010, 10:32 PM
bumpyfruck bumpyfruck is offline
Re: omg plz help
If you are going to drop the oil pan anyway you might want to consider installing rod and main bearings and an oil pump. all this costs about $130.00 if the crank is not scarred yet. If you let it go it will probably spin a bearing and ruin the crank costing much more later.
