Old 03-19-2010, 10:39 PM
lars0034 lars0034 is offline
Clutch Problems!
I have been having problems with my clutch on my 3000 gt. I have replaced both the master cylinder and slave cylinder and bleed the clutch and I still keep getting air in the system which causes me to lose pressure until I bleed the clutch again. I'm not sure what else to do to fix the issue. Any help would be appreciated!
Old 03-20-2010, 02:28 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Clutch Problems!
Are you sure you are getting air in the system?
You either need to adjust the clutch pedal, or if its a non turbo, get rid of the clutch damper located on top of the trans and just run a line straight from the soft line into the slave.
Old 04-07-2010, 10:54 PM
I think that fixed the problem thanks for your help!
