Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-19-2010, 09:56 PM
pkrieter pkrieter is offline
Question Bleeding ABS W/O diagnostic computer
To bleed ABS brakes,the standard proceedure is to bleed the brakes, use an ABS diagnostic computer to cycle the ABS system, then bleed the brakes again. I know that when you start the car and begin to drive, at about 3 miles per hour, it cycles the system. If I raised the car off the ground,start it,and put it in gear, and accelerate it until I hear it cycle the ABS system, will this allow me to properly bleed the brakes without having to buy the expensive ABS diagnostic computer?
Old 03-26-2010, 12:09 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Bleeding ABS W/O diagnostic computer
It should. The vehicle doesn't know if it's actually moving or jacked up.
This is the first time I've heard of the computer being used...on all my vehicles, I've bled the brakes as normal, even with ABS.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-27-2010, 10:17 PM
Thanks. I've seen it suggested many times and I know most people don't want to go buy an ABS diagnostic computer just to bleed brakes
Old 03-29-2010, 11:24 PM
hundahunta hundahunta is offline
you only need to bleed the abs if you replace the hydraulic control unit
Old 03-30-2010, 09:47 PM
Good to know. Thanks .......
Old 02-20-2012, 03:29 PM
e40water12 e40water12 is offline
Smile Re: Bleeding ABS W/O diagnostic computer
I think the only time you need diagnostic computer for ABS is if you trip the module into default mode. Then you need to recaliberate system. The same old school non Abs bleeding the brakes works, the same as Abs way/ Just don't allow the master cyl to run out of brake fluid.
Tags
abs , bleeding , diagnostic , tool
