Old 04-15-2003, 05:16 PM
hondatool hondatool is offline
Question P30 Ecu???
Anyone have any info or specs of a P30 ECU?
are those jdm?..thanks
Old 04-15-2003, 07:15 PM
94civic's Avatar
94civic 94civic is offline
i don't know about the specs, but they are not only jdm. they have this ecuin the 94-95 del sol in america. in japan they have the p30 in the 92-95 civic sir2, integra xsi, and the 94-95 del sol(i think)
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 04-16-2003, 04:38 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
What kind of spec are you looking for?They were availible from 92-98 in OBD I and II with the B16A powered vehicles around the world.Speed limiter depends on where it came from in Japan it is around 112,in the states it is probably set around 130,here in Germany there isn't one.P30's look for a knock sensor,unless it came from Europe,they don't run knock's here.Vtec crossover is 5500 rpms.The rev limit is 8500 I believe,but could be wrong.Other than that if you want like fuel maps and specific info like that you'd need to get a hold of one and some software to read it,or find somewhere that already does.
Old 04-20-2003, 12:30 PM
i was gonna use if for my SIR II cuz i have a 99 US SI ECU in it right now and i heard the an OBD 1 p30 would go really good with it?..anybody know about this?
Old 04-20-2003, 03:29 PM
Well what car is it in?
Old 04-20-2003, 10:19 PM
the swap is in a 99 civic EX
Old 04-21-2003, 01:41 PM
You need a B16A SiR from 96-98 (OBD II) which also runs a P30,but the OBD I's have different plugs and the OBD IIb 99-00 Si's have the same plug,but use the 3rd section
Here is a picture with the differences
Top to bottom they are
OBD IIb (left 3 plugs used)
OBD II ECU
OBD I ECU
OBD 0 (JDM PR3 and PWO)
