Old 03-19-2010, 02:35 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Question Auto-trans not shifting down @ stop
'91 Metro auto-trans is not shifting down to 1st when @ stop when in drive or second. Must down shift manually to first. Any ideas? I am new to the metro systems. Thanks, Bearwulf
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 03-19-2010, 04:40 PM
syrjr1 syrjr1 is offline
Re: Auto-trans not shifting down @ stop
Your chassis brain is bad. Mine would only act up in hot weather. I got one from a junk yard. It is a small electrical box located under the dash right of the steering wheel shaft.
Old 03-19-2010, 04:54 PM
Bearwulf's Avatar
Thanks again!!! Know where there are a couple of parts cars to check for the brain.
97-Lumina LS
Old 04-04-2010, 11:30 PM
Zechariah Zechariah is offline
Hey, did you replace the chassis brain yet? did it work? My car is doing the same thing (i.e. not down shifting to first when stopping some times.)
Please let me know I would really like to get this fixed.
Thanks,
Zechariah
Old 04-05-2010, 03:10 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Could also be a bad shift solenoid, or a bad connection in the wiring going to the shift solenoids.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 04-12-2010, 03:50 PM
HannabilRox HannabilRox is offline
Could also be the shift cable adjustment on top of the tranny. I know if I gingerly put my shifter in drive, it starts out and stays in 3rd gear. If I put it in Drive with a little force, it runs perfect. The other idea about the automatic transmission control unit is viable as well.
Old 04-27-2010, 11:44 PM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
Yea, I had the same issue a couple years back. I replaced both shift solenoids and problem solved.
Old 05-03-2010, 01:54 AM
Bearwulf's Avatar
Yes, I got the brain replaced and did cure the problem on mine. Sorry it took so long to get back, but have been very busy with grandson.
97-Lumina LS
Old 05-18-2010, 11:42 AM
Can anyone tell me where the shift solenoids are located on the 1997 Geo Metro lsi 4cly auto. ?
and is there a kick down solenoid on the car? if so where is it?
Thanks,
~Zechariah
Old 05-18-2010, 11:44 AM
Thanks,
~Zechariah
Old 05-18-2010, 11:45 AM
Thanks,
~Zechariah
Thanks,
~Zechariah
Old 05-19-2010, 04:20 AM
Woodie83's Avatar
They're inside the tranny, if you remove the pan, you'll see them.
Woodie
Old 05-28-2010, 04:05 PM
Okay, thanks. What would I call them when I go to order new ones?
also are they easy to replace?
Thanks,
Z
Old 05-28-2010, 05:43 PM
91 ragtop 91 ragtop is offline
Thanks,
Z
I have a 92 trans computer that might work. I''l let you try it to see if fixes your problem. Ken...
