Old 03-19-2010, 01:43 AM
viggy58 viggy58 is offline
just an FYI - lining up dist / oil pump
Long story short, my clutch slipped while i had the dist out and the car in gear. Chevy and an ind. mechanic each wanted about $250 to completely reset the timing. It drove OK once it started (SES light on), but i didnt want to chance driving it a ways (or spend $250!)
Reset everything to TDC but couldn't seem to get the dist to line up right. Every spot I tried was off by a tooth or 2 in either direction. I got a little intuitive and realized that with a LONG flat blade screwdriver, inserted in the dist shaft, i could spin the dist receiver on the oil pump (It spins pretty freely). Took about 30 mins of guessing and checking until i got it positioned where the dist went in on the right tooth, but it worked.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 03-19-2010, 11:12 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: just an FYI - lining up dist / oil pump
To set the dist right this is first step.
http://files.automotiveforums.com/ga...hp?photo=51302
Then after you get it started and running the camshaft retard needs to be set with a good engine capable scanner.
A good repair shop should not charge more than a hr labor set dist and check and set camshaft retard.
MT
Old 03-19-2010, 02:47 PM
old_master's Avatar
Advisor/Moderator
This might help too:
You have to know how it works,
to figure out why it doesn't.
Old 03-22-2010, 12:06 PM
Markb873 Markb873 is offline
I found it easier to set the distributor where it should go. Then turn the crank a bit and the distributor will fall the rest of the way into the into the oil pump.
The cars on the lawn:
2000 Kia Sportage
1993 Chevrolet S-10 Blazer
1975 Radio Flyer Wagon
