Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-18-2010, 10:23 PM
arias04 arias04 is offline
2004 misfire
2004 p71 is misfiring 3 5 and 8 and my code reader is come up with a nuther code ignition coil c primary/secondary circuit malfunction what is that it has new coils and plugs
Old 03-19-2010, 07:19 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2004 misfire
Coil c is cylinder 3. A is 1, B is 2, and so on. Are all the coils and plugs new? Did you use quality parts? Like Motorcraft or Autolite? Ford does not like cheaper ignition parts.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-21-2010, 11:32 AM
Re: 2004 misfire
yes i have msd coils and i have autolite plugs
Old 03-21-2010, 11:35 AM
Re: 2004 misfire
is it the egr valve that is doing this
Old 03-21-2010, 12:16 PM
way2old's Avatar
TOKEN HILLBILLY
Re: 2004 misfire
I hate to say it, but to really diagnose it, it needs to be put on a scan tool with graphing capability. have you thought about maybe a partially clogged injector also? Problem is, there is just guessing going on. Are there any other codes? If the EGR were at fault the LTFT and STFT would be off.
Old 07-01-2010, 12:32 PM
papiichuulo papiichuulo is offline
AF Premium User
Re: 2004 misfire
where are the LTFT and STFT numbers supposed to be?
(I realize this thread is a little old, none the less, I have hope)
Old 07-01-2010, 03:33 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 2004 misfire
The fuel trims should be close to 0%. They both range from +/-25%. Usually, it's acceptable to be within +/-10%.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
