Old 04-15-2003, 04:00 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Wink Easy 2 Step way to Strip Paint off....
Here is a easy way to strip paint off ur models, i dont know if this was used before but it worked great for me.
Step 1: Get some cotton swabs, and get some Nail Polish Remover
Step 2: Get some Remover on to the cotton, and swirl circles on the paint, and the paint will simply come right off.
Hope this helps some people.
Old 04-15-2003, 04:06 PM
ChopinPorkChop's Avatar
ChopinPorkChop ChopinPorkChop is offline
Send a message via ICQ to ChopinPorkChop Send a message via AIM to ChopinPorkChop Send a message via Yahoo to ChopinPorkChop
i agree with this method, u no wat your car is looking like as your doing it, as in if u were using brake fluid, u wouldnt know if say the plastic was warping and such..
My Msn: [email protected]
Old 04-15-2003, 04:07 PM
=p
yeah.
Old 04-15-2003, 04:17 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Note: The key ingredient is most nail polish removers is acetone. All warnings for acetone will apply to this method. Also, acetone can be diluted with preferably distilled water.
I work slowly!
Old 04-15-2003, 04:21 PM
Sidewinder-03's Avatar
Sidewinder-03 Sidewinder-03 is offline
Yeah, that will work until you "rub" through the paint and melt the plastic underneath it. Most fingernail polishes are laquer based and the remover is formulated to remove those laquer based polishes, and we all know anything laquer based does not get along with styrene plastic. I would *strongly* advise against this technique as I have severely damaged a few really good models, but if you have figured out how to use it without wasting a top project, then more power to ya. I'm just speaking through 17 years of experience.
Old 04-15-2003, 04:23 PM
freelunch's Avatar
freelunch freelunch is offline
Use Easy-Off oven cleaner. It works well if you spray it and let it sit for 3-4 hours before using a toothbrush to get rid of the paint. Also, I've let a Tamiya WRX sit in easy off for over a week with no bad effects.
Old 04-15-2003, 04:24 PM
=p
Well cuz ur using different paint, i guess. But it works very well, the way im using it.
Old 04-15-2003, 04:30 PM
daggerlee's Avatar
Maybe the brand of his nail polish remover is diluted enough as to not harm the plastic...If so, that's cool.
Dan
Old 04-15-2003, 04:31 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
Beware, it might be fine now, but wait , a nd your plastic will most likely be very weak, and mght break... its what happend with my corvette a while a go
Old 04-15-2003, 04:32 PM
It doesn't matter what type of paint it is, that stuff WILL damage the plastic. Trust me on this. But if you're into making your own mistakes then go ahead, consider yourself warned.
Old 04-15-2003, 04:38 PM
Here's a tip for ya, pour some of the remover into a container(something disposable), and then put a small piece of plastic from a kit (like the parts tree) in it and let it sit for a few mins.(5-10 should do well) and take it out. Now tell me, do you want that stuff on your models.
Old 04-15-2003, 04:47 PM
=p
Its not like im dumping half of the bottle on to it. I only need a little to take off alot....
Old 04-15-2003, 04:50 PM
You have been warned.
Old 04-15-2003, 04:51 PM
I didn't either. I used the same tecnique as you, it's just that i did it a couple of years ago.
Old 04-15-2003, 04:54 PM
DSM-Mark's Avatar
I'm curious now... can you try this for us?
EDIT: Sorry, wrong quote. The part about the sprue in a glass of nail polish remover...
I work slowly!
