strange wear on left side tires...
hi,
I have a 1990 Integra GS, i've had it for about a month now, and today i took the left wheel off and noticed that about on the inside part (about 1-1/2 inches) is completely bald, but the rest of the tire is fine... i looked at the back tire on the same side (left side) and it has the exact same thing. My tires on the right side are just fine, all even. but these on the left, they have this area on the inside which is completely balded. My mechanic has told me earlier that i need a rack and pinion job, my alignment is a tiny bit off, and my rotors are slightly warped (these are the problems that I know of). anyone have any ideas as to what might be causing this? |
its probably because you have negative camber. is the car lowered? if so get a camber kit and if not go get an alignment
1994 civic ex - b16a sir2 w/lsd too much to list http://www.cardomain.com/memberpage/423478 |
Camber does not wear your tires as quickly as toe. Get the car realigned and that should fix your problem. You really do not need a camber kit unless you are dropped more than 1.5-2".
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
