Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-15-2003, 01:11 PM
Paonessa Paonessa is offline
Finally got my y pipe on...
it makes an obnoxious blappling noise until 2500 rpm. it's fast as hell but i'm not totally happy about how it sounds. anyone with a y pipe and cat-back know what i'm talkin about? i'm hopng it'll get a little quieter after the pipe gets some exhaust resin built up inside.
Old 04-15-2003, 02:20 PM
thrasher thrasher is offline
Re: Finally got my y pipe on...
what does "blappling" mean, that's a new one on me:huh: :cwn27:
"Don't have sex man. It leads to kissing and pretty soon you have to start talking to them."
Steve Martin.
Old 04-15-2003, 03:06 PM
when the shit goes blap blap-POP when you let off the gas. that's funny though, it's a common reference 'round here with my friends. i guess it's just lots of back pressure
Old 04-16-2003, 06:22 AM
Pick Pick is offline
Mine doesn't have that problem. Should subside later.
Old 04-16-2003, 06:43 AM
NJMAXSELTD NJMAXSELTD is offline
Y Pipe + Cat Back = Noise, it will not get quieter.
Y Pipe + Stock = Just a slight change of tune, not really heard inside the car.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 04-16-2003, 08:16 AM
it's definitely an attention getter. espeailly at WOT. i'll deal with it. it's such a nice increase in performance that i can live with the sound.
Old 04-16-2003, 11:18 PM
http://forums.maxima.org/showthread....hreadid=207390
check that shit out man, maybe you can get the info you need
Steve Martin.
Old 04-17-2003, 11:23 PM
99maximagxe 99maximagxe is offline
How was the install. Did u install it yourself or a shop did it for you? Im planning on getting one next week. Did it come with new bolts and gaskets. Just curious how long will it take to install the pipe? thanx. o btw did you reset your ecu after u put on ur y pipe. People say u get the maximum gains by doing that.
Old 04-18-2003, 12:14 PM
i had a shop do it, but only cuz the bolts were so damn rusted on. the cat gets so hot sometimes the metal fuses. since you have a 99 you're bolts probably aren't as bad as mine, all it came with were the 2 metal o-rings and a new gasket. if you can get the bolts off easily the removal of the old pipe and the new install should be done in less than 1 1/2hours, even less if you have an impact gun and a universal pivotal socket attachment for it. i didn't reset my ecu. the only reason to do that is if the Check engine light comes on so the maxima's ecu can "relearn" how to drive with the new mod. plus i have a 95 which is an obd-1 ecu so i don't think those have to be reset. the obd-2 chips are the ones with all the extra programming they might have to be reset.
there were a few places where the exhaust rattled where it never had before. i guess all the air moving through now makes the exhaust move a lot more. one place it rattled was where the b pipe for my cat-back hit the heat-shield above it and the other part further down the b-pipe hit the actual frame of my car. nothing a heat shield and wrap couldn't subside. i wish i had gotten my y earlier. best 160 bills ever spent
Old 04-21-2003, 05:21 PM
pruizgarcia's Avatar
pruizgarcia pruizgarcia is offline
I just bought my y-pipe and had it installed. Should have done this a long time ago. Nice little rumble with a big, big, big rumble at WOT. Love it.
Pedro
Mi Maxima
Old 04-21-2003, 06:16 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
if any1 did it themselves, how hard was it? im planning on ordering mine after prom is over with
Old 04-22-2003, 04:35 AM
It is not hard with the right tools, but I was worried about rusted bolts, so I took it to a shop for the installation.
Pedro
Mi Maxima
Old 04-22-2003, 07:34 AM
Caracicatriz's Avatar
Caracicatriz Caracicatriz is offline
Me and my father started installing it ourselves until we got to the "cat" The bolts were impossible to take out. We ended up taking it to a local shop and getting the bolts loosened. Then we finished the job later.
