Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-15-2003, 09:17 AM
54963 54963 is offline
Rebuilding the Engine
Not say'n that I'm going to do this or anythign, but what are the times and how difficult is it to pull and rebuild and reinstall the engine on a 98-99 gsx?
thanks,
Bill
Old 04-15-2003, 10:39 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
if you dont know ablut engines dont do this!
give it to an experienced machanic to do cause if u re-build the internals and the spec are off it can and will screw up the whole engine timing cause the engine 2 preform poorly.
parts you might want 2 chang is the pistons and connecting rods, lower compression, hone the block and fix the crank walk if u have any....
i would leave it 2 a expert tho..
1
Shift_BOOST
97 s14
Old 04-15-2003, 01:59 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
You don't have to pull the engine to rebuild it, just the oil pan and head. Compression is already 8.5:1, leave it or go to 9:1. The best would be to swap to a 6 bolt motor completely.
