Old 04-15-2003, 08:24 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Loose Clutch Pedal
I just had my exedy clutch put in by AAMCO and damn its grabby but the problem is that before my clutch pedal was nice adn tight, but now it takes almost nothing to push it in, what could this be?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 04-15-2003, 09:35 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Give it time for the pressure plate to get broken in. Make sure that you break the clutch in properly. No hard shifts or hard driving for the first 500 miles. I wouldn't shift above 3,000 rpm's for at least 500 miles or the clutch won't last as long as it should.
Old 04-15-2003, 06:02 PM
Jay eS Iye's Avatar
so when the plate gets broken in the pedal gets stiffer? i hope so, but i know i need to tighten the cable b/c i got a bunch of play in the pedal before it actually hits the clutch, how do i tighten that?
Old 04-15-2003, 06:17 PM
Adjust the cable where it goes to the"arm" on the tranny. There is a little adjuster and you turn it accordingly. Leave at least 1 inch of freeplay.
Old 04-16-2003, 06:20 AM
Jay eS Iye's Avatar
ok i'll hafta go out today and see if i can see what you are talkin about (i'm real new to Hondas), i'll also check my Chilton's... how do i measure the play it has, and why go with an inch, any particular reason?
