Old 04-15-2003, 05:44 AM
n2it4sq n2it4sq is offline
HB's rear windows
This past weekend I decided to take out the side rear windows to remove the ancient window tint. I had already removed the tint from the other windows. My problem is that the two screws that secure the window frame to the car will not tighten up when re-installed. Has any one else had similiar problems?
Is it ever truly finished?!!!!!!
Old 04-15-2003, 11:08 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I've got that problem right now. My passenger side window is loose. I haven't really gotten around to checking into it, but it shouldn't be too hard to fix... maybe a bigger screw?
Old 04-15-2003, 11:45 AM
canned4thgen's Avatar
canned4thgen canned4thgen is offline
Send a message via AIM to canned4thgen
i had the same problem and i did what ci5ic said. i just used a larger screw
Old 04-15-2003, 12:53 PM
redmanjd redmanjd is offline
the thing is behind that white plastic insert their is a nut. and when you take the screws out the nut falls down so you have to line the nut back up
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 04-15-2003, 05:15 PM
Thanks for the info...............................
