Old 04-14-2003, 08:40 PM
Crxce Crxce is offline
Send a message via AIM to Crxce
fuel pump question
does anyone know if the extra pump from a aeromotive racing fuel pump gives you more hp cause of the better supply of fuel,
Old 04-14-2003, 08:46 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
you wont gain any more power, cause even tho you are giving more fuel, the air is still the same. you'll end up running pig rich, and just waste gas.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 04-14-2003, 09:03 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
You can get the biggest fuel pump that you can find and it won't help you out at all stock. It won't give one ounce more fuel to the motor. The fuel pump only pumps the fuel to the motor not into it. The injectors are what determines what goes into the motor. If you want to increase your fuel, get a FPR.
