Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 04-14-2003, 07:24 PM
MatthewRyan182 MatthewRyan182 is offline
Send a message via AIM to MatthewRyan182
Starting Problem
Hey guys I need everyones help on this one.
I got a '85 318i, and i'm having some starting problems. When i go to start it up i'll turn the keep and you hear the engine trying to start up but it takes a long time and sometime never to start up. So far I have replaced my rotor and distributor cap. I have checked my spark plugs and their wires, they all check out fine. This is where i need everyone to fill in the blanks, if ya got time help out. Thanks.
Matthew
Old 04-15-2003, 10:09 AM
m5runner m5runner is offline
Send a message via Yahoo to m5runner
did you do anything recently like take it through a car wash?? i hope not. i had something like that happen to my 92 and it was the crank sensor. i would also check fuel pump and brain box and making the brain being the last thing you check. good luck and post your results.
M5
Old 04-17-2003, 05:06 AM
beamer adam beamer adam is offline
Cool Starting Problems?
I had the same problem on my '89 e30 316i. the problem is a fuel pressure problem with there being a small valve controlling the fuel flow. Does the car start straight away the second time if she doesnt the first time? the problem is that there is no fuel at the engine and it has to come all the way from the tank. Not exactly sure what part it is but it could be the fuel pressure regulator located under the inlet manifold or else maybe there is a flow control valve between there and the tank.
Old 04-17-2003, 06:20 PM
Hey thanks adam, i'm looking into it as we speak. I'll write back to everyone.
