93 Transsport 3.1L Motor. Ignition in on position lights all gauges. Starter recently replaced. Turn ignition on - no response. No clicking, nothing. Battery is strong (tested) - when last used, began to start - then quit and would not restart. Check engine light is on - thoughts? Thanks.
Re: 93 Transsport 3.1L -Won't Start
Do you have power on the purple wire at the starter when you try to crank it?
Have you tried starting it in neutral?
www.avigex.ca/xport/starterdiagram.jpg
ONce starting problem is solved, here is how to read Check Engine light (not related to starting) www.avigex.ca/xport/readingcodes.jpg www.avigex.ca/xport/codes31.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Good Morning All - Tks for the quick responses.
Others may also have this problem - this is what it turns out to be for me: "Neutral Safety Switch" - just like it sounds - this "cut out" will keep the van from starting if the van "thinks" it's not in Park and such. Replacement here runs about 193.00. (Rawr) but less than a car payment. Thanks again everyone - :-) |
