Old 03-17-2010, 09:42 PM
mickyxoxobaby mickyxoxobaby is offline
Exclamation HELP, horrible noise coming from under the hood
My 01 pontiac grand prix gtp with 99,544 mi just got an oil change and a full tune up. the engine light just came on AGAIN. ALSO sometimes when i fisrt start driving, a high pitched noise (like sawing through 2x4's) happens when i accelerate. it goes away after a while though...serpentine belt?
and today the brake warning light came on when i was driving....my fluid is normal, and there is nothing wrong with my brakes...it went off after i toughed the brakes....wtf?
why is my engine light on? bad 02 sensor? my mpg is fine
what is that noise?
should i ignore the brake and engine light?
im 20, a girl, and i need your help lol
THANK YOU!
Old 03-17-2010, 09:47 PM
Re: HELP, horrible noise coming from under the hood
maybe alternator bearings?
Old 03-17-2010, 10:04 PM
i think its coming from the timing belt
Old 03-18-2010, 12:06 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Your car does not have a timing belt. Does the noise change as you turn the wheels? Have you checked power steering fluid level?
Would there be any possible way to get a sound clip or video of the noise?
Bring it to autozone or Advance. They scan your car for free. Just make sure you get us the actual code (Pxxxx) and not trust the parts guy with diagnosts. They make comission on parts and are willing to sell you anything even if it doesn't fix the issue. Without the code, the SES light could be on for a million reasons and we could guess all day.
And the Brake light, was it the Red "BRAKE" lights, or the Amber ABS Light?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-18-2010, 01:32 PM
l67cooled l67cooled is offline
Does the sound your experience sound like marbles in the intake? I remember a lot of people experiencing that particular sound which would slowly go away as the car warmed up. Problem turned out to be the supercharger's coupler. I don't think GM had a replacement part and tried to get you to put a new supercharger on. Aftermarket companies sell couplers that are much better than stock and problem can be fixed with about $50 and a hours time.
As for the check engine light; I would have to know what code its throwing. Go to autozone and have them do a scan for you; then come back on here and post said results.
ABS light will usually come on when fluid is full or a wheel sensor is failing. If the fluid is low I would bet you have a sensor going out ( pretty common ) This will only disable your traction control and abs; it will not effect your breaking other than that.
