| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Wiring Engine
I have got to a stage in modelling when I wanr to take my engines to the next level. I am only fifteen and live in Australia, so it is a bit hard to get those models oil lines etc. I was wondering if anyone knew a very cheap way of wiring the engines. I was think of using actual wiring that my brother has for his train modelling but I don't know how to secure it???
or 2010 QMHE Intermediate Silver - Mini Cooper S 2010 QMHE Intermediate Bronze - 37' Delivery 2011 QMHE Intermediate Silver - Panzer Tank 2011 QMHE Imtermediate Bronze - McLaren M8B |
Re: Wiring Engine
Howdy from Texas!
Your brother's train wire might be just right. Compare the thickness of the wire against the engine and see if it looks right for spark plug wires, or radiator hoses, or such. If you are lucky, it will already be the right color. Bare wire looks good for fuel and brake lines. The easiest way is to drill a very small hole where you want the wires to go. Place a very small drop of super glue onto the end of the wire and carefully insert it into the hole. When the super glue has cured the wire should be secure enough to bend a bit and to connect to the next part of the engine. The trickiest part is doing distributors. They are very small and it can be easy to make a mess of things here, so practice on some spare pieces first. This is the simplest way to get it done and should be a good starting point for a beginner. However, for more advanced and more realistic appearances, there are plenty of people on this forum that will tell you their techniques as well. Also, I believe there is a tutorial or two somewhere on this site, but I don't remember where. Good Luck! |
Re: Wiring Engine
Hey!! i'm just down the road from you on the Gold Coast!
You can get the correct wiring from online stores http://www.thepartsbox.com/ or off ebay sometimes i go to Spotlight ( with my girlfriend )and have a look thru their craft/bead/scrapbook section otherwise try you brothers wire see if the scale looks ok just a drop of super glue will hold it to where you want it we'd love to see some of your work!
Re: Wiring Engine
Thanks for the tips
I haven't got much on my USB at school right now but I have got one of WIP's (now finished) countach79, do you now of the shop, BR Models and Merchandice at Helemsvale. I think it is the best shop for well priced models in South-East QLD F.C
Re: Wiring Engine
yeah i was just at BR's the other day only got some styrene tho
Re: Wiring Engine
It's good he had started stocking Tamiya.
I bought the XJ220, I'll put the pictures up this afternoon in the Completed projects section!!!
Re: Wiring Engine
awesome can't wait!
Re: Wiring Engine
Re: Wiring Engine
The cheapest way to wiring your engine without spending so much money. You wont believe how cheap it can be. After seeing how much those company charge for a 3" wire is STUPID ridiculous. Here my way. I buy those extension phone line 300 feet for 1.50. now if you cut inside there are 4 color wire. Red, Green, Yellow and black. As I watch tv I strip the whole 350' wire and cut them by every 5" and tied them up for future project. Remember there is 4 color and 350' now do the math. 350x4= 1,400 feet of wire for 1.50. Ok now for Boot!! I buy large coated paper clip at a $1.00 store and they come with 25 pcs. They come in all color. I stretch the clip, I take a Xasto knife slice the clip in the middle and pull each end. I have now a hollow tube and the phone wire fit right inside of it. A perfect fit. I spend $3.00 and I can wire 20 model. Go and buy both wire at a hobby store for 20 car..HECK NO.
Last edited by ROCKIESJR; 02-05-2014 at 07:29 PM. Reason: Adding 1 image so they can understand but i cant. |
Re: Wiring Engine
The hobby industry sticks wire worth 2 cents in a package and charges $6 and it often doesn't even look very good! If you want to start detailing engines start saving scraps of wire from around the house. Every time you throw away an electrical item take it apart and snip the wire out of it. Even wire that looks way too big is often composed of smaller threads inside that may be perfect. The insulation can be used for radiator hose. The tiny motors in hard drives have winding wire that can be wrapped around a toothpick to make a throttle spring. You can paint bare wire if you first coat it with metal primer. Sometimes the plastic insulation on wire is too shiney but it can be dulled down with fine sandpaper to look just like neoprene rubber. Bottom line, scrounge. Ask people who repair things at work or school to save bits of wire for you. I never throw anything away without giving it a once-over for detailing materials. And I rarely buy anything for detailing.
| The Following User Says Thank You to CrateCruncher For This Useful Post: | ||
ROCKIESJR (02-05-2014)
Re: Wiring Engine
For my bike kits in 1/12 I use vinyl fishing line. I use .2 mm for electrical wiring and larger diameter for clutch and brake lines (.4 and .6 mm). Line can be painted in any color you like using your basic acrylic paint.
/Joel |
Re: Wiring Engine
If you ever do a How to on throttle spring. please pm me. There is one here but the pic not clear. I aways wanted to see it done.
