Old 03-16-2010, 09:08 PM
kenny94 kenny94 is offline
2001 s-10 4.3 miss and p0300
got a 2001 s-10 with the 4.3l had miss and changed cap,rotor, and plugs.ran fine for 2 months and now runs really rough,have to keep rpm at 1500 or high to keep truck running.checked codes and had a code for crank sensor,replaced that and code went away.test drove and had code p0300/multiple misfire.checked on here and alot of people say to use only ac/delco cap and rotor, i just got autozone ones.thanks in advance for the help
Old 03-24-2010, 09:31 PM
old_master's Avatar
Advisor/Moderator
Re: 2001 s-10 4.3 miss and p0300
This is why people on here say to use AC Delco ignition parts and NOT to use Autozone ignition parts if you want your vehicle to run: http://www.automotiveforums.com/vbul...44#post6100044
Get an AC Delco cap and rotor on there and let us know if you still have problems.
You have to know how it works,
to figure out why it doesn't.
Old 04-01-2010, 06:16 AM
ac delco cap and rotor fixed the problem,thanks for the advice.
Old 04-01-2010, 08:45 PM
old_master's Avatar
Advisor/Moderator
Glad you got her going! Thanks for posting back with the fix.
