Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-16-2010, 09:03 PM
JamesonT JamesonT is offline
99 Contour-engine light on, stalling
I have a '99 Ford Contour SE (4-cylinder, 2.0 liter engine) with approx. 87,000 miles. Recently, the "Check engine" light started staying on, and approx. a week or two later the engine started very randomly cutting out while idling, driving, etc., after which it starts, and runs, fine. It's been doing this for several weeks now, and while the problem hasn't gotten any worse, nor has it improved. The Onboard Diagnostic (OBD) computer suggests that the engine is running lean. It's been suggested to me (by a Jiffy Lube oil change center) to have the fuel filter replaced and the fuel injectors thoroughly cleaned (for approx. $109), though I'm hesitant as to whether the problem could be something other, i.e. a defective sensor, fuel pump, etc. Any input would be greatly appreciated. Thanks!
Old 03-24-2010, 02:46 PM
AnthonySisk AnthonySisk is offline
Re: 99 Contour-engine light on, stalling
Had the same problem with mine.Unplug the airflow sensor and see if that doesnt help
Old 03-27-2010, 01:30 AM
Davescort97 Davescort97 is offline
Escort guy
If you unplug the MAF sensor the computer will make the mixture rich by default. This doesn't mean the MAF is bad. More than likely the car has a vacuum leak which is causing the overly lean condition. Either that or it is starving for fuel which could be a result of a clogged fuel filter.
Tags
contour , ford , stalling
