Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-16-2010, 06:55 PM
kornjulio kornjulio is offline
Need help with turn signals-nevermind!
OK, so I'm finally enjoying my "turn" to have turn signal problems.
Symptom: RH side flashes fast (front & rear). LH side flashes normal. Hazards flash normal at all four corners. No recent bulb changes. No ABS/TC lamp. No changes to RH flash rate when brakes applied. Rear tail lamps function normally other than the RH turn.
Diagnostics: Pulled both tail lamps looking for infamous overheating condition. Pulled all bulbs, sockets looked fine. Removed electrical connection & inspected: looked normal, no burned/melted condition.
With the RH side sympton present, removed front peanut bulb. Rear still flashed fast. Changed peanut bulb. Still flashed fast both front & rear.
Where do I go next?
ETA: I got it figured out. Took me a while to realize the turn system encompases three bulbs/side, not two as I had thought. Pretty sure my front 3157NA bulb had a bad filament for the turn. Embarassing....
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
Old 03-16-2010, 08:59 PM
roadrunner2 roadrunner2 is offline
Re: Need help with turn signals
Be proud that you were able to figure the fault out on your own, a lot of others may not have.
Looks like you've replaced everything but the rocker panels. How are they?
If you've had this van from new (and it spent it's life in Florida) I reckon they are not rusted through, or does the proximity of salt air have an effect there?
The problem with doing nothing is not knowing when you're finished.
Old 03-17-2010, 04:17 PM
I'm not actually in Florida - but I wish I had the sunshine....
...here in the midwest, the rockers are as you'd expect...
Old 03-17-2010, 06:36 PM
Fudge...new bulb didn't fix it....looks like I'm diving into the wiring. Pulling down electrical schematics for this weekend project.
