Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-16-2010, 10:54 AM
barfarlanaa barfarlanaa is offline
97 2.0 wont start
i have a 97 contour 2.0 wont start have spark and fuel ( don't know pressure ) and timed perfectly but still wont start any advice at what to check
Old 03-27-2010, 01:35 AM
Davescort97 Davescort97 is offline
Escort guy
Re: 97 2.0 wont start
Clean the connector to the CKP (Crankshaft positon sensor) if that doesn't help replace the CKP.
Old 03-28-2010, 02:10 PM
z28clone z28clone is offline
I'd say get rid of the POS.
Found On Road Dead
Old 03-28-2010, 02:30 PM
Ralph123's Avatar
Ralph123 Ralph123 is offline
Try spraying some carb cleaner into your throttle body while turning the key and see it fires up for a few seconds.
Old 03-28-2010, 11:21 PM
Escort guy
He already knows the engine is getting spark and fuel. I don't see what difference carburetor cleaner is going to make. HOwever, starting fluid may make a difference.
Old 03-29-2010, 12:06 AM
Ralph123's Avatar
He said he didn't know the fuel pressure. So how does he know his problem isn't fuel related? Carb cleaner acts the same as starting fluid when sprayed into the throttle body. If the car fires up when spraying carb cleaner into the throttle body it would indicate he has a fuel problem. If nothing happens when he sprays carb cleaner into the throttle body it would indicate an ignition problem.
