Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-15-2010, 05:31 PM
LieutenantCracker's Avatar
LieutenantCracker LieutenantCracker is offline
99 Marquis: Where to place jack stands?
Yeah, I figured it out before I saw your reply-- THANKS, though!
I was lifting the rear-end to install "spring-lox" (coil spring compressors) to lower the back-end of the car-- It was riding too high, since I had the air suspension replaced w/ coil springs. I just jacked it ar the jack-point, then placed the stands under the rear axle,
I should've told y'all what my project was, in the first place.
Now that I've gotten the darn thing up on stands, I found that the springs are too high / the bolts that came w/ the compressors are too short, for me to get the nuts attached so, I guess I'll have to get comperable, but longer, bolts from the hardware store, tomorrow (as Advance Auto Pts didn't have any such thing)-- But that's for a different post (if at all) I suppose.
________
Harmed by paxil
Old 03-15-2010, 06:27 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 99 Marquis: Where to place jack stands?
Depends on what you are doing. I usually place the stands under the frame. You can move them to the outside of the jack(toward the rear on rear/front on front). This will give you a stable stance on the vehicle.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
