Old 03-15-2010, 04:57 PM
jimmyrood's Avatar
jimmyrood jimmyrood is offline
distributor cap and rotor
how can u tell if they are bad
Old 03-15-2010, 05:16 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: distributor cap and rotor
A dist cap can have a crack in it causing it to arc or misfire and also the carbon button that the rotor rides on can wear out. Also the terminals on the inside will erode away with use.
The end of the rotor will also erode away with use and if there is a lot of black dust on top of it, it means it has wore away the carbon button on the dist cap.
These are cheap enough items and if it has been a while since they were changed, they should be replaced as part of a complete tune-up..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
