Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-15-2010, 08:08 AM
timborama2001 timborama2001 is offline
Right Turn Low Fuel Stutter Stall
When my tank is slightly lower than 1/2 tank. It will stutter on steep up hills or right hand turns. Stall if I floor it. It has an almost new Fuel pump & new Pickup screen on it. Please help. Could it be that the tank is not sealed from outside air?
Old 03-15-2010, 01:58 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Right Turn Low Fuel Stutter Stall
What year is your Mustang? If it's a newer one with OBD-II you will have the MIL illuminated with a code stored for EVAP failure if the gas tank isn't sealed properly.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 03-15-2010, 02:11 PM
Thanks for the quick reply. It is a 94 mustang. I know that the tank spout is noot sealed as last time when I installed the new pickup that it was never tight where it enters the tank. Would that cause iit if air can get in the tank. How could I seal it iif so. I notice on my other car that when you open the tank to put fuel in it hisses like its compressed or something the mustang doesn't obviously because air gets in through the inlet pipe as mentioned above. The metal harness which holds the fuel pump in also appears to hold a larger fuel pump than the one installed. It is a correct aftermarket model nfor the car though I checked. Could someone have installed larger or performance fuel injectors and needed a larger fuel pump for it. If so would that cause the problem. Or would that happen at all times and not only right turns. Thanks again for any help
Old 03-15-2010, 03:02 PM
If they have bigger injectors and the tune and MAF to go along with it, than the fuel starvation would be a problem any time you hit the throttle past what the fuel pump can provide. And air getting in the tank would not cause it to stall out, but would be an EVAP system failure if checked.
Old 03-24-2010, 09:25 PM
OldSVTGuy OldSVTGuy is offline
When was the last time you changed the fuel filter?
