Old 03-15-2010, 12:35 AM
4x4 blazerguy 4x4 blazerguy is offline
Smile Turn Signal Flasher Removal ??????
First where is the turn signal flasher on a 97 Blazer 4x4 & how do you get to it to change it out?
Thanks.
Old 03-15-2010, 09:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Turn Signal Flasher Removal ??????
Thanks.
First find the power distribution box.
The 4 way and reg flasher is located in the power distribution center.
Let us know how it goes.
What is it doing or not doing?
MT
Old 03-15-2010, 11:33 AM
I was off-roading & dirt running for a hundred miles or so & when I got to the next town I realized I had no turn signals. Which I had before. The fuse is OK everything else works except the turn flashers. So I figured the flasher either vibrated out or shorted out. The hazard is in the middle of the dash by the radio & I have read that they are together. So that being the case I'm going to remove the middle hush panel & lower dash & try to get to it.
I'll let you know the results hopefully tonight.
Thanks
Old 03-15-2010, 07:22 PM
On the 97 Blazer the flashers are next to the lighters in the center of the dash. They are the round two prong same as they have used for years. The Hazard & Turn are side by side. You have to pull the lower center part of the dash off & the hush pads to get to them. I understand the 98 & up are behind the glove box You just need to pull the glove box down & it is right above the actuator.
