Old 03-14-2010, 05:24 PM
kpott14 kpott14 is offline
98 XJ drivetrain? u-joints? flexplate? problem
I have a 98 Cherokee Limited 141,000 miles. My problem is that i recently started to feel a "rubbing" while driving, can hear it too. It is great enough that it slows me down if im not on the gas, theres alot of resistance. I can throw the trans in neutral and it goes away, and i should say the trans still shifts fine so could it be the driveshaft? I should also note that this started happening after i had about 8 people in the jeep so could the weight have somthing to do with it? Thanks alot.
Old 03-14-2010, 07:57 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 98 XJ drivetrain? u-joints? flexplate? problem
My first guess is that all the weight caused the suspension (probably in the rear) to bottom-out so hard that a brake line became crushed. This would prevent the brakes (again, probably rear) from releasing fully, so they are dragging.
Old 03-15-2010, 08:20 PM
Ah yes, that makes alot of sense. I should add that the rear is sagging, the leaf springs look nearly flat and i dont know the condition of the shocks but i assume they could be needing a changing. Thanks man.
Old 03-16-2010, 04:11 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
For the leaf springs, any competent spring shop can re-arc the springs and add a leaf to keep them from sagging again. I've had it done on more than one old vehicle, and it works wonders - and would help stop this from happening again.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-16-2010, 07:58 PM
How much does this run you usually?
Old 03-17-2010, 02:00 PM
Wow, it's been quite a long time since I had it done....$150 maybe? Well worth it, makes the rear suspension almost like new. Add a set of new shocks and you'll be good to go.
Old 03-18-2010, 07:59 PM
Thanks man great help. I now have a pretty bad vibration when im accelerating. Could this be a U-joint issue? This is my first rear wheel drive car so im new to this haha
Old 03-19-2010, 11:56 AM
Accelerating vibration. OK, is it rapid or slow? Any noises accompanying the vibration? Can you feel it in the steering wheel or your seat?
Old 03-19-2010, 07:20 PM
To answer the rapid or slow question, the more gas you give it the worse the vibration gets. I can feel it everywhere in the car it just vibrates everything. There is also a "clicking, tapping" sound coming from the trans/torque converter area only while accelerating briskly ( i've heard this could be loose bolts on the torque converter possibly?) Thanks
Old 03-20-2010, 11:29 AM
At 141k I'd suspect the Ujoints first. While you're under there, taking the cover off and checking tightness on the flex plate bolts isn't a bad idea.
