Old 03-14-2010, 02:52 PM
zerotohero192 zerotohero192 is offline
Sunroof and o2 sensor questions
My power sunroof motor for my '94 base 3kgt can be heard when I press the switch, but doesn't move at all. Now I've heard of people using window motors (in a very old thread, can't remember where) to convert their manual sunroof to electric. Could I do something like this or would it be better to get the actual motor? Or does anyone have a sunroof motor for sale? Also if i remove a catalytic converter do I have to run a O2 simulator?
Old 03-14-2010, 05:05 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Sunroof and o2 sensor questions
If your 94 has a power sunroof its not factory.
If you remove the cat you do not need a sim since there is no o2 sensor after the cat.
Old 03-14-2010, 10:52 PM
I think the guy before me got the parts from a totaled 3000gt, later model. If so where can the motor be found online? Also I have the cali-spec emissions but I want the fed-spec 3sx downpipe, if I remove the precats do I need a O2 sim for those also?
Old 03-15-2010, 05:36 PM
Stealthee's Avatar
You cant use a fed spec downpipe because you are cali spec. It will not bolt up. Youd need Fed spec manifolds.
Old 03-15-2010, 06:48 PM
Stealthee's Avatar
Also on the power sunroof, is it glass? If so then its definitely aftermarket.
Old 03-16-2010, 11:20 AM
Yes it was glass, I'll just have an autobody shop check it out. As for the downpipe, I can't find them on 3sx anywhere anymore. oh well thanks for helping out a noob. Oh and that twin turbo conversion I was gonna attempt last summer/fall, it was getting way to expensive. Should've listened, lol.
Old 03-16-2010, 04:13 PM
Stealthee's Avatar
3sx is currently out of stock on the downpipes hence why you cant find them. Someone posted up saying they would be back in stock in 2 weeks.
Old 03-19-2010, 03:20 PM
hey stealthee or anyone else would an exhaust shop or autoparts store carry the flex section and piping for a fabricated fed-spec downpipe (turns out i have fed spec)? also the sizing of the piping and flex section too. thanks.
Old 03-19-2010, 03:23 PM
Stealthee's Avatar
When the downpipe on my Eclipse broke at the flex once I went to a local exhaust place and bought a flex section for like $25. I dont remember the sizing though,.
Old 03-19-2010, 05:46 PM
so should i just wait for the 3sx pipe, or would an exhaust shop be just as good and around the same price? Possibly a bit more with install?
Old 02-04-2016, 07:08 PM
hollydolly hollydolly is offline
Where can i find a sunroof motor 1995 3000gt sl.used preferabaly
Old 02-04-2016, 08:06 PM
Stealthee's Avatar
You can try www.3000gtstealthsupply.com or www.3swarehouse.com
I've bought from both of them and they both have a good amount of used parts.
