Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '04+
Old 03-14-2010, 02:28 PM
jgentil jgentil is offline
05 jetta transmission fluid
How do I fill the transmission with fluid? Where is the filler cap? 2005 VW Jetta with a 2.5 L engine.
Old 03-14-2010, 04:08 PM
Franco2112 Franco2112 is offline
Re: 05 jetta transmission fluid
No fill port to check. You have to suck out the fluid through a drain plug at the transmission. The transmission fluid is considered a lifetime fluid and does not need changing or fluid to be added. The only time you service the transmission is when you have problems shifting or loosing fluid around the transmission. Are you having problems?
If so, take to the dealer for ultimate satisfaction. If not, you need to do nothing until service time. Check your service manual.
Franco
Old 05-02-2012, 09:05 PM
gmbwrenchn gmbwrenchn is offline
Franco
Does this pertain to a Jetta GLS 2.0 Ltr. as well? Thanks.
Old 05-02-2012, 09:50 PM
Yes.
Old 11-03-2012, 12:09 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
There is a fill plug on the auto trans. If looking from below on the front there is a red cap. You have to break the cap off an thn remove the plug. Fill from there
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
