Old 03-13-2010, 10:46 AM
ditchmagnet ditchmagnet is offline
2002 Caravan - Wiper/Turn signal switch problem
The lever for the Turn signal/Wipers is not working correctly.
Sometimes when you try to signal to the right, the left one starts clicking, but if you jiggle it then it will work right, and sometimes it wont work at all.
Some times the wipers wont turn on unless you jiggle the lever.
Is this any easy fix? Is something just loose or what part would need to be replaced?
Thanks.
Old 03-14-2010, 08:56 AM
Bear Bear is offline
Re: 2002 Caravan - Wiper/Turn signal switch problem
Sounds like the multi-funition switch is bad (common on '96-01 Caravans). It is easy to replace, you need to slide under the steering column, remove the plastic cover around the column, and replace the lever (switch), it comes as a complete assembly and is about $70.00 at mos auto part stores.
