Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-12-2010, 06:12 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Enginge problem code P0505 Idle air/speed control system
Symptoms:
-Car idle sputters from 2000 RPMS to 3500 RPMS when in neutral
-Car drives itself when in gear or jerks back and forth as if someone is putting their foot on the pedal when in reality I am not pushing the gas pedal at all.
So I got a diagnostic code back from my OBD2 Scanner.
P0505 Idle air/Speed control system,
what does this mean exactly? Does this mean the part needs replacing? Or is there a way to fix it, for example could there be a leak or something stupid messing up the whole thing!?
is this part i need ?
http://cgi.ebay.com/ebaymotors/IDLE-...item27a4752180
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 03-12-2010, 08:53 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Enginge problem code P0505 Idle air/speed control system
I would see if you can test the one you have before you go and spend that kind of money. Look into a repair manual and see if you can test yours with a ohm meter. Testing resistance is really easy and worth doing before you go out and by one.
Here's a used tested one that's a lot cheaper if you need to go that route
http://cgi.ebay.com/ebaymotors/94-98...23141009r38618
Old 03-12-2010, 10:14 PM
good idea, I will take it to a mechanic and then tell him the error code.
then he can test it, see if theres any cleaning needed, and vacuum leaks
if it all checks out then i need 300 dollars for a third idle motor..
I replaced this part before with another used one I got for 50 dollars
[email protected]
Old 03-13-2010, 10:22 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Ya honestly it could just be dirty. The ISC can get plugged and not work properly. Just pulling off the TB and taking off the ISC and cleaning out all the little duct work could solve the problem. Also, check the TB gasket. When I blew my gasket, the air bypasses the ISC (IAC on the 420a but still the same thing) and threw a CEL because the IAC couldn't adjust enough to compensate for that extra air coming into the motor.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-13-2010, 08:19 PM
I guess I will buy some carbon cleaner tmrw.
The only thing is I cant work on my car where im it I dont have a garage here and its always rainy or cold.
I think if the idle motor was bad it would just die out all the time, it doesnt die at all it still idles strong but it idles up and down and up and down and then drives itself when its in a gear....
thought it was the MAF but the engine code says different
[email protected]
Old 03-14-2010, 12:24 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Check for vac leaks like Dave said. If there is a leak somewhere the ISC is going to try and close to restrict the air coming in. But since it has no control over the air coming in the motor idles high. The ECU doens't pick up leaks in the intake manifold and assumes that there is a problem with the ISC and its causing the problem.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-14-2010, 05:45 PM
clonetrooper84 clonetrooper84 is offline
I had that exact problem a week ago.Its the ISC sensor. Just go to the junk yard and grab one. I did and it cost me 5 bucks.
