Old 03-12-2010, 02:29 PM
msmith69oldz msmith69oldz is offline
Exhaust Help Please!!
Hello! My brother has a 2000 s10 pickup 4.3 v6 4x4 165,000 miles. runs great. Problem is it failed inspection for an exhaust problem. They said the y pipe needs to be replaced and the part itself would cost $650! I cant find it online anywhere to buy an aftermarket y pipe.Is this y pipe easy to remove if we find one at a u-pull-it auto salvage yard? Or can anyone suggest where to purchase one at a reasonable price? Thanks!
Old 03-12-2010, 02:44 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Exhaust Help Please!!
Was it the dealer quoting $650?
Call around to some muffler shops and see what they offer or you could locate one in a junk yard.
$650 seem a little high.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 03-12-2010, 03:14 PM
Actually it wasnt the dealer it was a local Midas. Quakertown,PA Took it in for state inspection they said it would cost a total of $2100 to fix everything to pass! By everything I mean front and rear brakes and rotors and the exhasut problem.The $650 was just for the y pipe they also want $159 to install it. I been searching online and I think I havent been able to find anything on a Y pipe because it looks like they only sell a catalytic converter assembly. So if im not mistaken I probably wont be able to get one at a junk yard because it is illegal for them to sell used catalytic converters right?
Old 03-12-2010, 05:51 PM
Blt2Lst's Avatar
I did not realize it was an assembly with cats, that would explain the price.
I would still call around to a few different shops.
And yes, it is illegal to sell used cats so a used assy might be out of the question.
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 03-21-2010, 10:23 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Technically the factory style y-pipe included the pre-cat and main cat and runs from the manifolds to the rear of the transfer case where it bolts up to the muffler. I believe walker did make a replacement for $350-$400, not sure if they still do, as well as Magnaflow (but only for 2wd). Its a pain to remove. There are 3 studs on each manifold and nuts holding the y-pipe on. These will probably be rusted and both the studs and nuts are known to break off. Each side has a donut gasket that fits between the manifold and the y-pipe. There are also two bolts in the rear that connect it to the muffler and tail pipe. Once its all unbolted you will have to pull it toward the front of the truck over the trans crossmember to remove it.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
