Old 03-12-2010, 12:16 PM
Fastlane89 Fastlane89 is offline
Exclamation Ignition switch related repair question
Hey guys,
So we've triangulated our electrical problems to the ignition switch area and im wondering how i would go about fixing an arcing problem with the contacts? This is of course assuming that my problem is not the actual switch itself but rather just a buildup of carbon at the contacts...
While i do know a bit about cars, im afraid as far as the electrical goes im a bit lost so if you guys have any advice or information, please go easy on the cranium!
Also, theres this big @#$*-off metal plate underneath the steering column, am i going to need to remove this to get to the switch?
Pontiac Grand Prix GTP, 1997
Old 03-12-2010, 08:20 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Ignition switch related repair question
I am confused, are you looking into replacing the ignition switch? There is write-up in tips and maintenance on how to do it. The metal plate to remove below the steering colum is a piece of cake to get off. Just 4 bolts and a couple nuts if I remember right.
Otherwise, check your Private Messages.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-13-2010, 08:26 AM
BNaylor's Avatar
BNaylor BNaylor is offline
See thread at link below located at our Buick Regal forum dating back to 2006. Same ignition switch, same issue related to carbon buildup and contact arcing. I've done it. Just have to take your time and put it back together properly and carefully especially the springs and cams.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 03-19-2010, 07:19 PM
keithwattles keithwattles is offline
The 1997 Pontiac Grand Prix has an electronic ignition system. I just replaced mine and it was a piece of cake. Go to eHow.com and ask how to replace ignition in a 1997 Grand Prix. They will give you a step by step instructions. As far as arcing, you would be best served to replace the electronics rather that trying to clean the contacts. You will need a switch specifically for a 1997, there is no interchange found.
