Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-12-2010, 12:16 PM
ken729 ken729 is offline
Check Fuel Cap light
Can anyone tell me what I should be looking at besides the fuel cap if the check Fuel cap light is on? Its not my vehicle but I sure would like to help the owner. There is no Check Engine light on. Any typical cause of this? Thanks. ( Its a 2003 xlt)
Old 03-12-2010, 01:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Check Fuel Cap light
Do you have access to a scan tool that will also report manufacturer-specific diagnostic codes? Just because the CEL is not illuminated does not mean that it won't have evaporative emissions codes or pending codes.
I'd suspect you have a vent solenoid system issue that is preventing the fuel tank from maintaining the correct pressure. It could be an issue with the fuel tank pressure sensor as well. Was a fuel filter or fuel pump recently replaced, by chance?
-Rod
Old 03-12-2010, 02:14 PM
Unfortunately i dont have a scan tool to put on it. I'm about 300 miles from home and just trying to help someone with the problem. There has been no recent work done on the fuel system. I thought perhaps there was a typical or most frequently found cause of this besides just the cap that I can look at. Thanks.
Old 03-12-2010, 04:31 PM
OK- I found a disconnected vacuum hose that goes to the evap solenoid. After restarting the light is still on. Do I need to reset the PCM or does it take time for negative pressure to build in the tank?
Old 03-12-2010, 05:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Is there an Auto zone or Pep Boys near? They will read the codes for free.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-12-2010, 05:47 PM
Thanks for the reply. There is an Autozone nearby - but the Check engine light is not on- only the check fuel cap light. Will that set a code?
Old 03-12-2010, 08:32 PM
Update---The light went out after the first warm up cycle.
Old 03-13-2010, 10:18 AM
way2old's Avatar
TOKEN HILLBILLY
Yes the check fuel cap will store a code.
Old 03-13-2010, 11:02 AM
Thank you for your help.
