Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-12-2010, 11:07 AM
kdemarest7725 kdemarest7725 is offline
rodeo crankshaft bolt
95 rodeo 3.2L v6 4x4. I believe it has jumped a couple teeth and need to redo the belt. I do not know what size the bolt is for the crankshaft though. Anyone have any idea so i can go buy the socket? And also i do not have any air tools so i will have to do this manually. anyone know how i can get the pulley to stay still?
Old 03-12-2010, 01:47 PM
Cat Fuzz Cat Fuzz is offline
Re: rodeo crankshaft bolt
The best way is to have a long-ish breaker bar and lay it on the frame, disable the ignition!!! and bump the starter. You'll never get it loose manually. IIRC, you'll lay the breaker bar on the drivers side of the frame. I forget what size socket it is.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 03-14-2010, 09:39 AM
dvd5904 dvd5904 is offline
A 7/8" socket will work (or metric equivalent). That sucks that you can't get your hands on an impact wrench. That is the only way I was able to get mine off and put it back on. If you have any trouble with the timing give me a shout. I just did mine twice a month or so ago. Wrong the first time, and right the second...lol.
