Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 03-12-2010, 08:05 AM
Darryl S Darryl S is offline
Rear Wheel Bearing Hub
How Do I Remove rear Wheel Bearing Hub On 1997 lincoln continental ?
Please
Old 03-12-2010, 02:38 PM
Towncar's Avatar
Towncar Towncar is offline
Thumbs up Re: Rear Wheel Bearing Hub
«1997 Continental Table of Contents»
«Group 04: SUSPENSION»
«Section 04-02: Suspension and Wheel Hubs, Rear»
«REMOVAL AND INSTALLATION»
Wheel Bearing and Hub Assembly
Removal
1. Turn air suspension service switch off. Raise vehicle on hoist.
2. Remove wheel and tire assembly.
3. Remove rear disc brake caliper. Support rear disc brake caliper with a length of wire.
4. Remove push-on nuts that retain rear disc brake rotor to wheel hub and remove rear disc brake rotor.
5. Remove front hub cap grease seal from wheel hub assembly.
6. Remove rear axle wheel hub retainer and discard. GET NEW AXEL NUT!
7. Remove wheel hub assembly from rear wheel spindle.
Installation
1. Position wheel hub assembly on rear wheel spindle.
2. Install new rear axle wheel hub retainer. (NEW AXEL NUT) Tighten to 255-345 N-m (188-254 lb-ft). Install front hub cap grease seal.
3. Install rear disc brake rotor on wheel hub. Install two push-on retainers that retain rear disc brake rotor.
4. Install rear disc brake caliper.
5. Install wheel and tire assembly. Tighten lug nuts to 115-142 N-m (85-104 lb-ft).
6. Lower vehicle.
7. Turn on air suspension service switch.
-Steven
1996 Town Car, Cartier
Old 03-12-2010, 07:59 PM
Mr. Towncar I thank you very much. That is just what I needed to know. Off to get a new axel nut, not sure why they don't come in the box with the hub.
Thanks for the help.
Old 03-12-2010, 11:04 PM
Towncar's Avatar
Originally Posted by Darryl
Thanks for the help
Hey Darryl.. if you need a copy of your 1997 FSM let me know, this procedure (less the graphics) was copied from the FSM.
-Steven
