Old 03-12-2010, 04:27 AM
3100 3100 is offline
Banned
p1406 on 97 GA 3.1L
Hello, did anyone have any experience with this code? I know there is a lengthy procedure how to test this etc. but I am just wondering if anyone had this code and found some shortcut for solution. I did have one extra EGR laying around which I already installed. Month later code is back.
Old 03-13-2010, 07:43 AM
andretti andretti is offline
Re: p1406 on 97 GA 3.1L
The position and flow sensors are all in the same unit. EGR flo must be o.k. since no p1401 code. All you can check is the harness. 12v at the pink, 5v PCM reference on one of the greys and the brown is EGR position to PCM.
Just sounds like you have 2 bad valves.
Old 03-13-2010, 10:57 AM
Banned
this is not tripod egr it has only one valve, any other ideas?
thank you 3100
Old 03-14-2010, 11:09 AM
Banned
freeze frame for p1406 any ideas ?
ENGINE SPEED 999 RPM
COOLANT TEMP 66 DEG F
VEHICLE SPEED 0 MPH
BAROMETRIC PRESSURE 71 IN HG
INJECTOR PULSE WIDTH 6.9 ms
LTFT -0.8%
MAP 14 IN HG
MAF AIR FLOW 9 g/s
STFT -0.8%
TP ANGLE 0%
Old 03-14-2010, 03:15 PM
I understand it's not a tri-valve. Your 3.1 for '97 should have a 5 wire harness connector, the position and flow sensors are integral.
