| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
have a problem with my 91 talon
i have a 91 talon non turbo its have some problems ok well it wont stay started and its lacks power like wen i get it started n start driving it the car holds back alot. n then we i come to a stop n push the clutch in the car stalls n then it wont start back up..
so far i cleanned the throttle body n egr n idle control valve. n the vacuum lines but wen its started i took the 3 vacuums off the top of the throttle body n didnt change the idle at all. isnt it supposed to tho.. i cant figure out whats wrong so please help thanks |
Re: have a problem with my 91 talon
Welcome to AF.
Please use some better grammar man, your post is hard to read and understand whats going on. The better we understand your problem the better we can help you. Does the car have a check engine light on?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
no theres no check engine light on at all.
oh sorry about the grammer earlier i was at work and had to write it fast. so sorry about that man. |
Please re-explain your problem so we can help figure this out.
Is this the 1.8l motor or the or the 2.0l? Does the car have a MAF on it? If so maybe air is getting around it so the motor is getting unmetered air causing it to run lean.
well it has the 2.0l n/t
the problems are: when you start it up its running fine but wen u get in the car and push the clutch in to move its stalls out. then it wont start back up and drains the battery. the starter finally went on it yesterday it like locked up. it has a push button start i dont know if that could be a reason for the battery draining or not? someone told me it could b the clutch but i just replaced it like a week ago. could that b the problem? |
So now you cant even drive it? It sounded like in your first post that it would drive but just sluggish.
From you last post it sounds like it runs fine but as soon as you push the clutch in it will stall or do you have to put it in gear before it will stall.
well no its just sluggish and has no power when im driving it.
and it dont have to be in gear it can b just running and idleing fine then when i get in and try to move it, i push the clutch in and it stalls out. then it wont start back up.. it like drains the battery |
Have you given the battery a good charge and checked to make sure the alternator is charging?
well i no the batterys nice n charged up but im not really sure about the alternator thought.
but the starter locked up so i need to get a new 1 tomorrow n check it out.. ill let you no then |
I had a mits eclipse and started doing the same thing. I took it to the mits shop and many dollars later, was told the alternator was shot. Well, after that little ride, I had it fixed and got rid of it.
edit.... Oh yea... it would drain the battery over night. |
ok well i just got some parts off my buddy of mine.
i got a starter , a alternator, gas tank and a intake mani. wm throttle body off a 94 talon so i hope it matches up. will it? i have a 90 talon. but ill let u guys no how it goes. |
ok guys
heres the problem now. my 1991 talon non turbo is still really sluggish n holds back power i just put a differant starter on it, a bosch alternator and some diff. spark plug wires. i took my 91 thottle body out of it and put a 90 throttle body on it.. its way differant but it runs tho.. like i had it running for like a hour today it was idleing a little bit wierd like its fluttering n trying to stay started it almost sounds like there a vaccum leak some where but i couldnt find any at all. but then i walked into my garage and it like cut out n stalled. i dont know where else to look for the problem. need some help guys thanks |
