Old 03-11-2010, 09:33 AM
PoorRichradsGTP's Avatar
PoorRichradsGTP PoorRichradsGTP is offline
Caliper Bolts Question
What do you guys use on your caliper bolts (the ones that screw into the rubber boots on the caliper) when you screw them back in? Do yall use grease? Any suggestions are welcome.
Poor Richard
Old 03-11-2010, 10:22 AM
GPFred GPFred is offline
Re: Caliper Bolts Question
I've used bearing grease and I've used white grease. Never had a problem with either. I did find that the bearing grease stood up to heat better than the white grease. I applied the grease after cleaning up the bolts first with a degreaser.
Old 03-11-2010, 10:40 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Syl-Glide, its made specifically for disk brake slide pins.
Old 03-11-2010, 01:35 PM
Brent S Brent S is offline
Yes, they sell special grease for the very high temps that calipers generally see.
-Brent
'99 GTP
