| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
'90 LX 5.0L 5-Speed Restoration Advice
I am hoping to begin restoration of my Mustang, which I've owned since June 1990, this summer and would like some advice from the forum members. My car has just over 222,000 miles on it. Other than the water pump and alternator the only component I've had to change out was the clutch, which I did back in November of 2008.
I would like to increase the output of the engine without going to extremes in cost; I think I could swing $2,500 on the engine and $500 on the exhaust system, maybe a bit more. I know I need to replace the lower controls arms on both sides and I think I need a new power steering pump. There are also a few interior items that need to be replaced as well, but first things first: What is recommended for the engine? I want it to run well and look good while keeping it as close to stock as possible. Can I get 250+ hp out of it very easily? What about the exhasut system? What size pipes do I use? What about mufflers? I want to minimize the back pressue in the system and get a nice deep rich sound. I plan on eliminating the cats since we have no inpsection where I live. Eventually I'd like to replace the rear drum brakes with disc brakes. Is there an anti-lock brake kit that could be added? Any other performance suggestions? Well, that's a start. Let me know your thoughts. Thanks.
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...-2005 Yamaha V-Star 1100 Custom ![]() -2008 Toyota 4Runner Ltd 4.7L AWD ![]() -2019 Subaru Ascent (the wife's)
Re: '90 LX 5.0L 5-Speed Restoration Advice
Put a turbo on it
![]() Magnaflow Turbos is what I run, nice and quiet. 2 1/2 should be fine. Rear disc are a waste, only 20% of the cars stopping power comes from the rear. Heads, ARF 165s, small cam 218 500 range, and you got 350hp easy, with a lot of low end torque.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Steeda underdrive pulleys will free up a few ponies and save your accessories some life.
http://www.steeda.com/products/steed...ve_pulleys.php Start running 93 (or 91, whatever your state has) octane fuel and advance your spark timing as much as you can before it starts knocking. This will add some torque and horsepower on the cheap - just the cost of the higher octane.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
As far as modding a motor, the first things that are musts are listed below. -Air silencer removed, add free flowing air filter -Exhaust, headers O/R or free high flow cats, free flowing mufflers -Advanced timing, 10*= stock, 12-17* range for advance -Under drive pulleys -GEARS, I know its not a motor mod, but its by far the best bang for the buck, espically when Ford loved the 2.73 gear ratio back in the day.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
Agree with 5.0
And yes gears and the first and best thing you can do for some speed. 3.73s with Trac-Loc are the way to go, IMHO.
A slower burn rate from higher octane will not create more power, as I mentioned earlier, you want a faster burn for better performance. The reason you advance timing is so you have more fuel/air in the cylinder when the spark fires. The quicker the burn, the faster you can make use of the additional fuel/air mixture in the cylinder. Again, you want to do this to the point without detonation for increased power. More for your reading enjoyment. http://www.consumertipsreports.org/the_truth_about_highoctane_gas.html http://tl.acurazine.com/forums/showthread.php?t=581978 http://www.ricehatersclub.com/vbulletin/showthread.php?t=9836
I agree with you there. Too much will cause a negative return of power and efficiency no matter what octane is used. Quote:
This I do not agree with. The purpose of higher octane and advanced ignition timing is to ignite the fuel/air mixture so that the flame front will meet the piston at the best possible moment to produce the most power. There's more too it, not all of which I want to get into without citing sources, etc. so I won't for now. But my tuner agrees who dyno tunes Ford Modular engines daily (V-6s, V-8s, etc.) with different octane fuels. He has dyno data to backup the claim that higher octane with advanced ignition timing will provide more torque and horsepower.
Well okay, I think I'll just agree to disagree and will have our own opinions.
But for the matters of the OP, we both agree that advancing the ignition a few degrees will add some performance and efficiency. It's up to him what octane he chooses to run.
Great discussion, but a little over my head. I've never messed with or even know how to check my timing. I have almost always run 93 octane since I bought the car back in 1990; have I wasted a ton of money by doing so? I do try to run true gas (ethanol-free) in it and am fortunate to have a couple of local stations that offer it.
I guess I'm afraid of messing up my performance by changing the timing after 20 years of it being what it is. Am I ignorant or paranoid or both? I have a manual that would I think instruct me on how to advance the timing and I can pick up a timing gun pretty easy. Will is really a difference? Thanks for the great info.
Also as I mentioned earlier, the basic mods for any 5.0 are as listed. -Air silencer removed, add free flowing air filter -Exhaust, headers O/R or free high flow cats, free flowing mufflers -Advanced timing, 10*= stock, 12-17* range for advance -Under drive pulleys -GEARS, I know its not a motor mod, but its by far the best bang for the buck, epically when Ford loved the 2.73 gear ratio back in the day.
Thanks.
Technically they don’t create horsepower, they free up lost horsepower form parasitic drag on the motor. What they do is slow down the rotation of the accessory pulleys by using larger then stock pulleys in comparison to the crank pulley which uses a smaller then stock pulley. So in turn you are using less effort to turn the accessories for each revolution of the crank pulley.
As a side effect, they can slightly improve the life of the accessories because they are turning slower, and increase MPGs for the same reason. Won't really be noticeable so don't expect to see it. Besides, you're in a Mustang
