Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-10-2010, 06:01 PM
earnman earnman is offline
Question 99 cummins trans p0753 pcm wiring
have code p0753......3-4 shift solenoid...not real familiar with this trans looking for a wiring schematic or diagram for trans and pcm and fuse box under hood. do not know where power comes from or goes to when unplug trans wire from trans no power there? 5v..no power coming from relay think wiring problem but do not have a diagram to go by. is there a place i can get a schematic?
Old 03-12-2010, 09:33 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 99 cummins trans p0753 pcm wiring
Will this help?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 03-12-2010, 12:12 PM
sure looks like it will help . will find out this week end and let you know
thanks
Old 03-12-2010, 05:32 PM
is this battery + voltage coming from relay or battery-?
Old 03-12-2010, 07:04 PM
AF - Advisor
Here's more,
Old 03-12-2010, 08:02 PM
AF - Advisor
Here's a most informative, complete thread with pics,
http://www.cumminsforum.com/forum/98...ired-long.html
Old 03-14-2010, 02:20 PM
thanks so much!!! thread and all the help made diagnoses so much easier!found solenoid bad replaced and all works good!! thanks again!!!
