Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 03-10-2010, 02:56 PM
dmrbigeshott dmrbigeshott is offline
How many miles do you get out of an S10?
How many miles, on average, do you get out of a s10 before you start having major problems assuming the fluids have been changed regularily?
Thanks
Old 03-19-2010, 01:58 AM
viggy58 viggy58 is offline
Re: How many miles do you get out of an S10?
that depends on A LOT of factors. I'd say right off the bat, a big factor is the coolant. if it has (orange) dexcool that hasn't been serviced, you can expect radiator, water pump, and intake gasket problems after 100k miles.
auto or manual transmission?
2 wheel or 4 wheel drive?
year?
mileage?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 03-21-2010, 09:44 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Like viggy said, every truck is going to be different depending on year, mileage, drivetrain, and how the truck was used. On a newer (say 96+) S10 with a 4.3 and 4wd, by 100,000 miles or so you will probably be replacing the lower intake gaskets, water pump, thermostat, tune-up items (cap, rotor, plugs, possibly wires), fuel pump depending on use, and most of the front suspension wear items (U/L ball joints, idler arm, control arm bushings, wheel bearings). A 2wd would be the same mechanically except for, obviously, the front suspension.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 03-21-2010, 10:40 PM
haha yea, forgot to add the fuel pump in there. my gauge hasnt worked in 3 years, but somehow the pump is still chugging along.
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Old 04-03-2010, 02:35 PM
jakeyf08 jakeyf08 is offline
I have a 96 s10 blazer. around 195k changed the intake manifold gasket and heater core, rebuilt transmission around 204k and it has 215k on it now and running strong. Depends on if you perform regular maintenance, helps avoid problems but cant completely avoid them!
Old 02-09-2011, 07:06 PM
maddiemae414 maddiemae414 is offline
I have a ZR2 1999 manual transmission awd with 280,000 miles. Have replaced clutch, fuel pump, master cylinder, and recently the coil. I believe that I have an ABS sensor out as the light is on presently, (my reason for being here). All in all, I love this car or would not being driving it presently. Have used synthetic oil since 150,000 miles, change it like clock work, and for the most part, the engine is great!
Old 04-19-2011, 07:48 PM
FishFind FishFind is offline
One Hot Shot
Mine is at 224k as of now replaced fuel pump 2 times and water pump 1 time. A/c don't work but that is all. If you don't mind a beater the engine will run for a long time.
