Old 03-09-2010, 11:44 PM
bsr2002 bsr2002 is offline
Turn Signal
TURN SIGNAL not working. Lights seem to be fine.
Old 03-10-2010, 12:26 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Turn Signal
Do any lights illuminate when you signal.
Old 03-10-2010, 09:04 AM
Re: Turn Signal
No, and the lights on the dash don't flash either.
Old 03-10-2010, 01:01 PM
Airjer_'s Avatar
Re: Turn Signal
I would start with a flasher. Should be under the dash near the steering column. If the four way flashers turn on you can follow the sound to the four way flasher. The turn signal flasher should look the same and be near by. One of the terminals on the connector for the turn signal flasher should have power to it. If you jump the two wires it should illuminate the right or left turn signal depending on the position of the switch.
Old 03-14-2010, 06:39 PM
Re: Turn Signal
The four way flashers don't work. I did find where the relay is and changed it out. Still nuthin
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 03-15-2010, 10:50 AM
Airjer_'s Avatar
Re: Turn Signal
One of the terminals on the connector for the turn signal flasher should have power to it. If you jump the two wires it should illuminate the right or left turn signal depending on the position of the switch. __________________
Did you check for power?
Old 03-16-2010, 08:19 PM
Re: Turn Signal
No power
Old 03-16-2010, 11:44 PM
Airjer_'s Avatar
Re: Turn Signal
At the turn signal switch there should be a pink wire. That is the power for the turn signal from the fuse. There should be power there with the key in the run position. If there is no power there than there is a problem between there and the fuse (assumeing you checked the fuse). If there is power there than check the Light Blue wire. That is the power out to the flasher. If there is no power there and there is power at the pink wire than the switch is bad.
Old 03-17-2010, 12:26 AM
Re: Turn Signal
I will try that! I did change out the fuses before.
Old 04-09-2010, 02:49 PM
McLin's Avatar
McLin McLin is offline
Re: Turn Signal
what is the result?
I have the same problem, no flasher is working self the hazard not.
Before I park my Lumina last year for winter season I had problem with driver side brake light and turn signal on same time.
Today I roll out the car, all lights are working, but no flasher in the dash, no sound from relay.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 05-21-2010, 10:43 PM
Thumbs up Re: Turn Signal
I changed out the turn signal switch and all is fine
Old 05-22-2010, 03:57 PM
Question Re: Turn Signal
Started car up for test drive and service light and airbag light are on. Is there a way to reset this?
Old 05-23-2010, 03:28 AM
McLin's Avatar
Re: Turn Signal
u must remove the black battery cable for 10 minutes, after this all trouble codes are deleted....
Best regards McLin.
My Lumina
Mileage:
Old 05-23-2010, 03:35 AM
Re: Turn Signal
I will try it...thanx
