95 Camry Power Steering Tough
1995 Camry 167K miles. Since November my power steering has gotten progressive stickier. Right now, turning the wheel left or right at a turn is tough. When making a turn, initially there is significant resistance, but once I get far enough, there is no problem and it feels normal. After completing a turn, the wheel doesn't correct to straight as normal, but I have to give it some encouragement.
I thought it was due to the cold, but it's in the mid 50s now and no improvement. I searched this forum and decided to flush/replace the power steering fluid with Dextron III using the link with all the nice pictures. This did not seem to help unfortunately. Turning isn't impossible, but I cant do it with 1 finger as before. Any ideas? |
Re: 95 Camry Power Steering Tough
Any noises while you're trying to turn the steering wheel? Groaning? Screeching? Does it steer easier if you turn the wheel slow versus fast?
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
No noises, screetching, or anything out of the ordinary. It seems to steer a bit easier when I turn it faster vs slower.
I added some Lucas stop leak power steering fluid to it. Man that stuff is thick. Seems to help a lot. I'll see how much better it is on the way home, but I can tell it's not normal. |
I think it is fixed. Or at least, it is back to normal 1-finger turning.
A friend recommended I try using Lucas Oil power steering stop leak. Man that stuff is thick. I drained the reservoir with a soap pump, and then poured the Lucas Oil product in. I then moved the wheel back and forth a few times - no real impact. Then I drove to work (30 miles on the highway), and moved the wheels all the way left and all the way right 20 times. That seemed to fix it. Could be a leak sealed, or the detergent portion cleaning it out, or perhaps removing any air bubbles. Getting the liquid hot seemed to make a difference. |
If it was my car, I would now remove the additive and replace it with ATF.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
